TwinTurbo.NET: Nissan 300ZX forum - Re: 17.7v seems way off but let's reverify the measure. DO NOT
TheKryptKeeper
on October 16, 2017 at 8:34 AM
posted by jzack
on October 15, 2017 at 08:27 PM
I can test a little bit later today, but when I cleaned and reconnected everything I got 13.3 across the battery with the headlights off and a battery at near dead. I charged the battery overnight and will check after work, but I'm hopeful.
New Alternator and Battery still not Charging
TheKryptKeeper
18:57:35 10/15/17
jzack
20:27:34 10/15/17
Re: 17.7v seems way off but let's reverify the measure. DO NOT -
TheKryptKeeper
08:34:53 10/16/17
Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT
TheKryptKeeper
22:19:02 10/16/17
Re: Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT
NIVO88T
10:32:05 10/20/17
If the dash bulb and check relay are good. Measure battery
jzack
19:43:49 10/21/17
Did you check the ground wire off the battery? (n/m)
Brad(RI)
20:44:12 10/19/17
Re: Did you check the ground wire off the battery?
TheKryptKeeper
10:02:00 10/22/17
